Fluid Changes?
Fluid Changes?
after reading the owners manual and service history guide i still can't find when to change the tranny, coolant and axle fluids. toyota's service guide would show the months and the miles when the changes were due. i saw the brake fluid which is every 3 years but the tranny and brake fluids were on every page as a checklist.
how often are these changes supposed to be done?
also, has anyone adjusted valves on their S2K and when you did how many miles did it have? longest car i kept was my celica gts and that had 70K when i sold it and never adjusted the valves. i'm planning on keeping the car for a lot longer than 4 years.
I'd look in the manual again, I know all the recommended intervals are in mine. Read the FAQ's in the Under the Hood forum/Technical forum, lots of good info there.
Most 'enthusiasts ' change their fluids before the recommended interval anyway.
Diff at 7500, Tranny at 15,000, and brake and clutch every 2 yrs here.
This is very odd. Perhaps it's because you have an '06 with that "oil minder" thing. All other owner's maintenance schedules do indicate a change interval for all these fluids.
Your engine oil is by "oil minder" but if you read your owner's manual carefully, you should see that there is a 1 year limit on this where you change it if the light hasn't gone off yet.
The tranny fluid in previous model years indicate a fairly long change interval, but those on this board have changed it earlier if shifting presents an issue. Mine indicates tranny fluid at 60K miles or 4 years under the "severe" schedule.
Although the manual indicates rear diff fluid at 15K miles or annually, it's not a bad idea to get the original fluid out of there sometime before 5000 miles to get all the break-in shavings out of there.
Brake fluid is every 3 years.
Engine coolant should be a Type II for your car and is supposedly good for 10 years, 120K miles. Best to check this after 5 years.
There is no valve adjustment interval. Adjust only if "noisey".
it's good to know that tranny can be changed at 60K under severe conditions and not at 30. i don't road race anymore because the $$ adds up real fast, just normal driving and a few montain attacks. i don't drag race legally or illegally since the celica so i shouldn't worry about my 2nd gear, plus i don't drive like i used too speed shifting every gear. Differential at 15K and coolant is at 120k. it would have been nice if these things were in the service history book.
