FIRST LAUNCHES WITH MY 06
Old 01-02-2007 | 08:31 AM
  #31
[AP2-2NV]'s Avatar
depending on the surface im on i launch anywhere between 4500 and 7000. usually closer to 5500 tho. tires will spin, but it doesnt sit there spinnign, it lunches off the line as its spinning.
Old 01-02-2007 | 11:58 AM
  #32
winson123's Avatar
Originally Posted by CKit,Dec 30 2006, 03:42 PM
AP1 FTW!
broken drivetrains ftl
Old 01-02-2007 | 01:58 PM
  #33
Rdrcr's Avatar
Originally Posted by FISH22,Jan 2 2007, 08:58 AM
how are you guys getting good launches over 5500 rpm. i'm guessing i just slipped it way to much, i know i didnt do an aggressive release.
Dumping the clutch at 5,500 rpm's is not for a good launch, that's if you want to do a nice burn-out.
Mike
Old 01-02-2007 | 02:36 PM
  #34
FISH22's Avatar
Mike
i'm sure if you go any lower, you'll bog, unless you slip the clutch a bit...and if you go any higher than 5500 rpm, you will spin the tires more.
Old 01-02-2007 | 07:38 PM
  #35
[AP2-2NV]'s Avatar
Mike
works great for a launch for me. as a matter of fact. if it's a sticky road i need to up it a bit or i bog.....that, will kill a differential.
Old 01-02-2007 | 10:41 PM
  #36
Aze85's Avatar
yup, it is the clutch delay valve, really ez to remove
Old 01-03-2007 | 12:22 AM
  #37
Empedocles99's Avatar
If you want wheelspin in your AP2, or a mediocre to moderately good launch (I am no expert at drag racing, but I can at least get wheelspin on demand), do the following:
Rev to 5.5-6k, sidestep the clutch, don't let it out slowly, sidestep it. By this, I mean, have just the edge of your foot on the clutch, and quickly move your foot out of the way (off to the side) of the clutch so it slams upwards. The CDV will let the clutch take a little of the driveline shock, and then after that your clutch will catch and you'll have as much wheelspin as your heart desires.
Old 01-03-2007 | 07:54 AM
  #38
Ks320's Avatar
Originally Posted by SIIK2NR,Dec 31 2006, 07:52 AM
On the contrary... if you leave it in and drive spirited.....it will shorten the life of the clutch.
Tim
Well, it helps Honda though! Honda probably doesn't need replace your clutch when its worn, but probably need to replace your diff from warranty if you know how to bend around the rules a little bit
Old 01-03-2007 | 05:04 PM
  #39
FISH22's Avatar
good point
rocrfella
10-06-2007 04:34 PM
Trent06
03-09-2007 08:03 AM
Dunk'sDad
03-11-2006 09:28 PM
kamrin
08-12-2002 02:27 PM
lvs2k
11-06-2000 03:08 PM
Quick Reply: FIRST LAUNCHES WITH MY 06
