Fading headlights
Old 02-27-2007 | 08:39 PM
AndyThomason's Avatar
Default Fading headlights
And all I came up with in the search were threads for clearing headlights and rick's diffusers. Soooo wanted to find out about how to remedy my fading headlights on my '00. Is there anything I can buy from a local store? maybe a polishing compound or something? thanks, andy.
edit, u can see here near the top what i'm talking about hopefully
Old 02-27-2007 | 10:05 PM
guardiase's Avatar
Yes, a polishing compound would help in removing that, but I would suggest using a machine along with the compound as it is really tiresome to work the polish by hand, since this is thick hard plastic you're dealing with and not thin paint.
For starters you can buy a bottle of Meguiar's PlastX, found at most auto parts stores, a microfiber or foam applicator, and a buffing towel.
Also visit the Wash & Wax forum of the site. There are plenty of people there who will help you out with this.
Old 02-28-2007 | 07:05 AM
GranPrix's Avatar
You didn't even need to search, all you had to do is go to the Wash n Wax forum....
https://www.s2ki.com/forums/index.php?showtopic=463970
Old 02-28-2007 | 07:35 AM
doheboy6's Avatar
You should really try and use Meguiars PlasticX. Comes in a white bottle and you'll find it at any autoparts stores.
Old 02-28-2007 | 07:46 AM
GranPrix's Avatar
Old 02-28-2007 | 10:30 AM
01silverstones2k's Avatar
will that stuff work on your back plastic window. (sorry for the thread jacking)
Old 02-28-2007 | 04:18 PM
guardiase's Avatar
Since the rear plastic was meant to be clear, yes. Meguiar's PlastX was made to polish any type of clear plastic.
Old 02-28-2007 | 05:43 PM
whitemistress2k's Avatar
Yes, that stuff works great IMO and I use it regularly on my headlights, taillights, and on the outside and inside of my plastic rear window...
Old 02-28-2007 | 06:41 PM
ej3ffrey's Avatar
ya, one of my buddies showed me how to do this... 1st you wetsand the headlights with very fine sandpaper, it will look really blurry... then add the platix and buff it out. made my headlights look brand new.
Old 02-28-2007 | 09:13 PM
silentdancer's Avatar
be careful when youre sanding! also for the people who asked about the rear window, make sure not to put too much pressure cause you can crack the plastic if you press too hard.
Quick Reply: Fading headlights
