EU Spec MY04-5 F20C Engine
Originally Posted by Wisconsin S2k' date='Feb 20 2005, 08:20 PM
this is what interests me.
a change in the primary reduction gear has the same effect as changing the final drive gear, since the primary reduction gear multiplies power the same way the final drive gear does.
so to the original person who said the 4.76 final drive ratio.
that is a MY00-03 FD WITH the primary reduction gear factored in. (4.1 times 1.16 = 4.756)
so, in the new 04-05 S2000, the effective final drive would be 4.9528. (4.1 times 1.208)
and since this affects every gear, it essentially was the same as changing the FD.
(if memory serves me correctly, the primary reduction gear is the gear that mates the 2 halves of the drive shaft together. there are 2 halves, because without having the drive shaft built of carbon fiber or something like that, the drive shaft would be too long to be one solid piece, and could cause problems with vibrating, durability, etc.)
Originally Posted by skastr@s' date='Feb 20 2005, 10:51 PM
they changed the final dif ratio from 4,1:1 to 4,76:1, thats why the new model has a better accelaration in 4th, 5th and 6th gear.
Dont believe everything Greek magazines say.
I think is the Power or the Evo magazine that has this wrong info.
Moreover, a different final drive applies to all six speeds and not just to 4th, 5th and 6th.
Originally Posted by skastr@s' date='Feb 22 2005, 09:49 AM
maybe THIS will help.
The OP specifically asked for the EU Spec MY04-05 with the F20C engine in it.
If you read the link that I provided above, it has the changes made to the EU Spec S2000 for MY04. No changes to the gear ratios have been made for the EU S2000.
Nobody is disagreeing that the USDM MY04-05 S2000s have slightly different gear ratios (mostly due to the change in the Primary Gear Reduction). But thats not what was asked originally.
