EPS Torque Sensor
EPS Torque Sensor
I need to memorize the torque sensor on EPS and i should follow the instructions as per below. I need to have a special tool SCS short connector which i do not have, Can i just short the 2 connectors on P2 (close circuit)??
P2
P2
Originally Posted by Stratocaster,May 24 2005, 12:39 AM
Trip
I have done this. I took a paper clip and shorted Pin #2 in the ODBII connector to ground. So don't touch the EPS Control unit.
Are you sure its Pin2 i have to short and not pin1 as described on http://www.baustnet.com/honda/misc/dtc.htm
After changing to a new complete steering rack/gearbox, after a turn, the steering wheel does not self center, It does not pull to any sides.
I also know that i need an alignment done too, I will get that sorted it and "re calibrate" the torque sensor
bes2k
07-19-2018 11:35 AM
