Engineers (or anyone, really) help me!
I'm doing a project for a vehicle dynamics class modeling an s2k. Can anyone tell me a site that would have more in-depth specs for this car?
Things like center of mass height, inertias and efficiencies of drivetrain components, etc.
So far I can only find the "normal" specs - wheelbase, weight dist f/r, gear ratios, etc.
How about a dyno data for a stock engine? even just a graph would be helpfull
Thanks for any help you can give me!
Mac
edit:- haha, I just saw Rob_s2k's dyno immediately below my post
Mac
Mass height? You mean the CG location along the vertical? That would be hard to find. Really all the things you want are difficult pieces of data to get without detailed 3d models (or at least good 3-views) of the car's components. You may be outta luck on this one.
YOu may be able to make some assumptions. If this is college level than I think some basic assumptions about efficiency would be fine.
yeah, I know it's a little more involved but I was hoping that maybe someone had done something like this already. It's not a big project or anything, but I'd like to have some numbers. Maybe I should cross post this in the racing forum, too.
Mac
Mac
I learned in college (engineering) that these types of problems are 99% assumptions. Otherwise, you'll be there for months solving the items needed to start the problem alone.
Just set a set of realistic numbers and go from there.
Being able to make a correct assumption is important, but you're going to find that getting the CG height wrong by not very much will really screw up weight transfer calculations (consider that it will be the same order of magnitude as the track).
