Eibach ProKit Question, HELP!!!
I recently put 18"s on the car and had a shop lower the car with the Eibach prokit.
2 things,
1-The front tires have more gaps than the rear tires,
2- the Front Right tire has 1/4 inch more gap than the front left.
is this normal or can it be corrected?
Thanks
2 things,
Thanks
side to side that isn't "too" bad, might check the tire press just to be sure. You don't mention how many miles are on the car as it might settle.
As far as the gap- Did the shop preload the suspension before tq the susp bolts? Have you measure from the ground up to the highest part of the fender to compare with OEM measurement (flat even groung of course)? You do know that the wheel arches are slightly diff front to rear?
The suspension needs to be pre-loaded. If it isn't you'll end up "winding up" your bushings when the suspension compresses causing some bad handling traits. You could pre-load your suspension if you have a jack, jack stand and some wrenches.
For us newbies trying to insall springs/shocks ourselves for the first time, how do you go about pre-loading the suspension prior to tightening everything up?
