Early AP1 Hardtop hardware
Old 07-11-2010 | 06:41 AM
BEASTMODE's Avatar
Default Early AP1 Hardtop hardware
I was checking out hardtopguy's site and the hardware is like $200 more for AP1s with a VIN under 5730. Does anyone know what the difference is between the kits. My car falls in this range and I'm looking for a HT, but Im not paying $800 for hardware if I can use something else.
Old 07-11-2010 | 08:49 PM
BEASTMODE's Avatar
Also, could I use the OEM hardware to fit a VIS top?
Old 07-12-2010 | 02:31 AM
xoz's Avatar
xoz
yes you can and the OEM hardware is the best way to fit replica ht's.
Old 07-12-2010 | 06:13 AM
BEASTMODE's Avatar
thanks a bunch.
Old 07-12-2010 | 06:31 AM
TPhong's Avatar
The older AP1's (00-01) do not come with a defroster because of the plastic back window. The hardtop does have a defroster. The kit is $200 more because it includes the defrost button and it's wiring.
Old 07-12-2010 | 09:17 AM
BEASTMODE's Avatar
that's what I kind of figured it was, but i was just making sure the brackets werent different somehow. Thanks for your help guys.
Old 07-13-2010 | 07:26 AM
Stratocaster's Avatar
Actually the early vin AP1 needed to have the center console and rear panels replaced in addition to the wiring. The coin holder was mounted with a plastic weld and not removable. Same thing
on the side panel bushes. To so install the top in the early vin Cars you had to replace these parts too. That is where the extra cash went
Old 07-13-2010 | 07:51 AM
04S2kSS's Avatar
If you dont care for the defroster you can get any...the mounting hardware is all the same...
you may want to upgrade the strickers tho for a tight fitting HT tho... May rattle a bit with old worn strickers...
Dre
howy007
11-02-2013 07:52 PM
Krisbuc
03-13-2013 09:45 AM
ddaniyol
08-04-2009 09:41 PM
wickedrex
04-08-2009 05:36 AM
vodoxus
09-11-2006 01:33 PM
Quick Reply: Early AP1 Hardtop hardware
