Driving With My
Old 11-16-2007 | 06:03 PM
kstokes's Avatar
Originally Posted by Agent.Marshall,Nov 16 2007, 04:29 PM
I've heard this and also that leaving your foot floating on the clutch is bad too.
Yup. Letting your foot rest on the clutch pedal is definitely bad news. It will cause the throwout bearing to drag, wearing it prematurely.
Old 11-16-2007 | 06:16 PM
Saki GT's Avatar
Originally Posted by RED MX5,Nov 16 2007, 08:34 PM
I was taught not to leave my hand on the shifter, or my foot on the clutch, break, or gas pedal, if I wasn't actually using them. The reason given for keeping my hand off the shifter was because it could produce greater synchro wear, but whether that's true or not, it is clearly better to have both hands on the wheel whenever possible, and if you are doing that, you can't be hanging on to the shifter.
It's a bad habit that keeps you from practicing the good habit of keeping both hands on the steering wheel.
Think of it all like toilet paper - you don't touch it until you need it.
Old 11-16-2007 | 06:20 PM
Enthralled's Avatar
I leave my foot on the clutch and hand on the shifter...do i care?
Old 11-16-2007 | 06:21 PM
Saki GT's Avatar
Be careful, I hear you can go blind doing that...
Old 11-16-2007 | 07:28 PM
MitsukillinS2K's Avatar
lol
Old 11-16-2007 | 09:28 PM
SIIK2NR's Avatar
It's a bad habit as mentioned.
You should not touch the shifter until you are ready to use it.
One you are done with the shifter you should return your hand back to the steering wheel.
Common sense applies. If you are downshifting through gears as you would to stop, your hand would remain in place. However on most upshifting, you should replace your hand to the steering wheel.
Additionally for safeties sake, you should maintain positive control of the steering wheel as much as possible.
Lastly, it will help with timing between your feet, hands and steering wheel.
Tim
Old 11-16-2007 | 11:10 PM
hipopkboy's Avatar
but...but...god hand in initial D does that! ...lol jk
btw i don't put my hand on the stick shift unless i have to shift, both hand is on on the wheel.
Old 11-17-2007 | 12:44 AM
innovation's Avatar
i did that just for fun for like 1-2 minutes... my hand kinda felt numb for a bit but that was it
Old 11-17-2007 | 01:20 AM
tak_one_77's Avatar
but the vibrations are good........
Old 11-17-2007 | 02:45 AM
CA_S2K's Avatar
Originally Posted by AlX Boi,Nov 16 2007, 04:32 PM
This topic has been discussed before. It was basically concluded through simple physics. The vibration has to go somewhere, right? If you hold the knob, the vibration will not be able to be released. Hence, the vibration goes back to the synchro causing more stress than usual. I don't think it does any real noticable damage. It's just something that's discouraged.
This is true, after getting a old car built at road race they told me "the shift noob is'nt a hand rest, your wearing things down".
Quick Reply: Driving With My
