Dreaded Failure
Old 10-13-2009 | 02:08 PM
macr88's Avatar
Originally Posted by CKit,Oct 13 2009, 02:36 PM
It'd have to be loose, loose. Not 185ft*lbs vs 225 loose.
That's not possible, if the bearing is going to spin it will spin with that nut on or off.
The only reason a hub is normally replaced is because it's easier than pressing the inner race off of it.
Old 10-13-2009 | 03:21 PM
CKit's Avatar
Maybe a more technical type can comment. But from what I understand (and I could be wrong): The axle nut gets loose loose. The bearing gets damaged from the play. It then spins in the race, galling out the hub. You take off the hub and the bearing just falls out. You can't just replace the bearing because the hub is now worn on the inside and a new bearing won't fit snugly.
Old 10-13-2009 | 04:49 PM
macr88's Avatar
When the cv gets pushed through the hub is it stopped by the bearing inner race or hub. For some reason I was thinking it gets stopped by the hub but it must press against the other inner race of the bearing?
Old 10-14-2009 | 03:42 AM
hicabi's Avatar
Bearings cost $80.
Old 10-14-2009 | 04:19 AM
HMFIC's Avatar
Originally Posted by hicabi,Oct 14 2009, 07:42 AM
Bearings cost $80.
36...
i have never seen so many mods in one thread lol
alot of "race"ism goin on too lol
bboykye
08-05-2008 01:32 PM
shuneycutt
07-24-2006 03:10 PM
geminigsr
South Florida
15
08-21-2004 06:47 AM
BioBanker
05-02-2004 06:51 AM
jdchaiken
10-16-2001 04:33 PM
Quick Reply: Dreaded Failure
