Downshift Rev match
Old 10-02-2008, 04:13 PM
lychyrychy's Avatar
Default Downshift Rev match
Hi guys,
Just want to get everyone's experience on this real quick
I normall blip the throttle 1k rpm while rev matching from 6th to 5th, 5th to 4th, or 4th to 3rd. However, when revmatching from 3rd to 2nd, I actually need to blip harder, if that makes any sense, to rev match ... how about everyone else? I have a MY05 if that helps.
Old 10-02-2008, 04:55 PM
Terror's Avatar
I think it has to do with the ratio of each gear. It is quite normal. I do it in my car all the time.
Old 10-02-2008, 07:09 PM
s2kvince's Avatar
It's due to the gear ratio as stated above.
The larger the difference between the two ratios, the larger the difference in RPM will need to be.
1st gear - 3.133
2nd gear - 2.045
3rd gear - 1.481
4th gear - 1.161
5th gear - 0.942
6th gear - 0.763
Old 10-02-2008, 08:19 PM
roflitzjinno's Avatar
yeah the ratios have to deal with it. the lower the gear youre shifting in its a higher rpm you have to rev to i think. when im going 30 in 3rd and downshifting to 2nd i have to rev to a bit above 4k.
Old 10-02-2008, 08:42 PM
white_turbo's Avatar
you have to redline it if you go from 2nd to 1st.......
j/k.....
Old 10-02-2008, 10:48 PM
lychyrychy's Avatar
Thanks for all the inputs
I thought it was weird at first.
Old 10-03-2008, 06:17 AM
hansai00's Avatar
Yeah it was like that my Prelude also. I was never able to do a smooth/fast rev match to 2nd gear. I feel like a lighter flywheel would take care of it.
Old 10-03-2008, 09:13 AM
hkspwrsche's Avatar
you could double clutch if you have time
Old 10-03-2008, 11:20 AM
lychyrychy's Avatar
^oh yeah! hmm good point.
Old 10-03-2008, 02:30 PM
ahrmike's Avatar
i double clutch 2-3 shift, 3-2 shift, 5-6 shift and sometimes when its cold, 1-2 shift.
unless im having fun revving high seems to make the shifts go in easy.
Quick Reply: Downshift Rev match
