Double Clutching
Old 06-26-2002, 03:15 PM
  #31
stocky's Avatar
You can even change gears without clutching if you're good enough.
Full throttle...let throttle go and at the same time push the stick slighlty towards next gear...when it feels lighter pull it out and at the right revs push it into next gear.
Just for info...I don't recommend it...I used to do it on my older cars when I was too lazy to engage clutch.
I had to learn it because the lever of the clutch of one of my cars broke some years ago so I had to drive around with no clutch.
Donwnshifting works as well but not that good.
I tried it once on my old 2000 S2000...worked there aswell.
Fastest upshifting for those street racing guys...push until rev limiter and at first fuel break push the clutch without leaving the foot from the accelerator an put in next gear. You have to be VERY FAST AND PRECISE.
But like I said...please don't do it with your S2000...it hurts if you don't do it right.
Don't do it unless you have to.
I feel already bad that I wrote this here...
Yves
Old 06-26-2002, 03:29 PM
  #32
BDMonk's Avatar
I used to occasionally shift without the clutch in the Formula I used to own, mostly just to maintain the skill in case I ever had to use it. I don't recommend doing it on a regular basis.
Old 06-26-2002, 03:34 PM
  #33
jjanicke's Avatar
Yves
I don't think you can drive a car without a working clutch. For sure you can up and downshift without using the clutch, I've done it in my S2000 and do it all the time in my Audi A4.
That being said it's impossible, as far as I know, to start your car from a dead stop without a clutch, unless you can get the car rolling down a hill or something. From a dead stop it's not possible without f..cking up your tranny.
Old 06-26-2002, 03:39 PM
  #34
stocky's Avatar
It is possible, 1st gear engaged..then start the car
Yves
Old 06-26-2002, 03:49 PM
  #35
jjanicke's Avatar
[QUOTE]Originally posted by stocky
[B]It is possible, 1st gear engaged..then start the car
Old 06-26-2002, 03:52 PM
  #36
stocky's Avatar
Dont park in that case...try to not even stop at a light
Didn't have any other choice
Was a '89 Opel Corsa GSI 100 PS @ 800 kg
Yves
Old 07-04-2002, 08:59 AM
  #37
vesendak's Avatar
you people are out of control cars are disposable
Relentless_AP1
08-13-2015 11:24 AM
lukemc01
01-01-2005 07:28 AM
dundonr
09-02-2003 09:41 AM
tkdsungjin
07-10-2003 06:42 PM
dierk
06-28-2002 06:23 AM
Quick Reply: Double Clutching
