Done installing top... slight problem
Just got done installing my new robbins top. Only one problem. The right side is fine but the left side has a couple wrinkles at the back almost like its not tight enough. I have no idea what would cause this or if its fixable. Cant see there being anyway to mess up the install, you just match the holes.
If anyone has any idea id appreciate it.
Ill double check that when I go out there later. I dont think its that, because the first time I closed it, it was hard as hell because it was tight and not stretched out, but the back was still messed up.
Doesnt matter anyways... Anything that could be it im not going to disassemble the whole car to redo.
pm joe from atl. His name is Cyclon36. He's very comfortable with the install.
This might help too. https://www.s2ki.com/forums/index.ph...T&f=1&t=448840
Leave the top up, park the car in the sun for a couple days. Mine had a couple wrinkles too when first installed. After a couple days in the sun stretching all the wrinkles went away.
S2Kuhn
03-20-2017 05:48 AM
