does anyone have any problems with the 2006 and above?
#25
#26
Originally Posted by FluKy15' timestamp='1318654505' post='21072241
My only problem was soft top straps got loose
http://modifry.com/products/index.htm
#27
My 06 just turned 50,000 miles this last week. I bought it with around 30,000. Had to replace top straps when I bought it as they were dangerously loose. Had to perform axle nut tsb. Headlights are hazing so need to restore them. Passenger side door woofer blew even though I hardly ever listen to the stereo. Threads behind the bumper broke and fell off making my front bumper hole tab covers crooked. VSA is overly sensitive after replacing rear tires with non oem tires but still proper dimensions. Now steps in whenever I take a turn the least bit fast. Slave clutch cylinder leaks and about a month ago in rush hour traffic clutch went to the floor and it became very difficult to shift. Bled the clutch and fixed the problem. Must have been air in the line somehow. Also, half of my gauge cluster backlights are out so that it is difficult to read the gas and temp displays. It recently threw a bad cat code but I cleared it and it has not reappeared. Only mod is K&N FIPK. It is a good car but has more problems than I anticipated of a relatively new Honda.
#30
Bought 2007 new in 08/07, 31K miles now:
(A) Drivetrain vibration since new, I think it's the clutch, dealer says no-problem-found and my independent mechanic won't replace w/aftermarket clutch on my nickel, I need to start over. Shifts poorly as well.
(B) On/off throttle hesitation
(C) Top problem, had tensioners replaced @ 2 years, it's doing it again, 2 tears repaired and now have two more, different ones
(D) Need alignments fortnightly but that could be local roads although I've lived here 55 years, never had this prob w/other vehicles.
