Do I need a Hardware kit to mount hardtop on 04?
check handaaccesories.com
I believe you will at least need kit C which is the cheapest of the 3.
The 00 needs A+B, the most expensive
the 01 and a few 00-03 colors need B
I think all the 04s only need C though.
if your car came with the hardtop then you already have the kit
it's a wireing harness that will allow you to use the rear window defroster, softtop bypass switch and two rear bracket's that allow you to insert the rear pins on the hardtop
