Differential fluid replacement?
Old 04-11-2006 | 06:00 AM
  #21
Wisconsin S2k's Avatar
Originally Posted by Ztopgun28,Apr 11 2006, 01:03 AM
so the rear diff. gear lubricant oil should be replaced every 5 oil changes/15K miles or so if driven hard?
you shouldn't be doing 5 oil changes in 15k miles. only about 3 oil changes.....
Old 04-11-2006 | 06:33 AM
  #22
revS2k's Avatar
I changed my diff. fluid last weekend and the car seems to be smoother overall. I dont know how to really explain it but after my diff. change their were less noises and the it was smooth. ONe question, is there a reason the top washer is copper?
Old 04-11-2006 | 07:29 AM
  #23
kntrider's Avatar
Have any of you gotten the tranny and diff fluid changed at a shop?
If so how much?
I understand that it's simple and you can do it yourself.
But just wondering how much it would cost.
Don't really have the proper tools to it myself.
Old 04-11-2006 | 08:03 AM
  #24
rustywave's Avatar
i was quoted $80 for a diff. oil changeat the honda dealership.
[1st time yourself - diff]
$25 for a good torque wrench
$12 for socket and wrench (see DIY thread in "under the hood")
$10 for mobil 1 75w90
$3 rubber tubing for filling diff back up
$0 jack in the trunk (though i used a hydraulic one + jack stand that was lying around)
[subsequent diff oil changes]
$10 for oil
edit: get a box of rubber gloves too...you shouldn't need anything more.
not sure about transmission fluid change at the dealership...but for DIY:
[trans fluid change]
$0 for torque wrench you already bought
$0 jack (though you should get a jack stand)
$3 17mm socket
$23 for GM synchromesh: FM (not sure what the other types cost)
$0 rubber tubing you already bought
and finally...
knowing your trans/diff wont fail due to incompetence at the dealership: priceless.
Old 04-11-2006 | 08:44 AM
  #25
johnny's Avatar
Holy Old Thread. to the person who used the search funcion...
Old 04-11-2006 | 09:15 AM
  #26
sunnyyan's Avatar
just changed both my tranny and diff fluid at 13k on my own, the quote from dealer was $180 for tranny, not sure about diff but I'm assuming won't be cheaper. So saved $300 by changing on my own.
I would change my tranny and diff every 15k miles
Old 04-11-2006 | 09:19 AM
  #27
CoralDoc's Avatar
The board was only a couple months old when this thread started. And I'm still here 4 differential fluid changes later .
deegaw11
12-29-2012 12:27 PM
omgitsoop
06-08-2007 08:55 PM
Balboa
10-03-2005 08:28 AM
C6400hp
06-05-2004 12:33 PM
deadpedal
06-06-2001 07:42 PM
Quick Reply: Differential fluid replacement?
