Dealing with a no grip oil pan bolt...HELP..
so the last time i changed my oil, i over torque'd the bolt, now today i went to change it, i messed up the whole bolt...its got no grip on it now. Anything out there i can do for less money than taking it to a weld shop and have them weld on another bolt on top of the old one and unscrewing it that way?...
i've heard of JB-weld, but not sure if it actually works well...its like glue..but gotta have time to let it dry...so...help would be nice
![redface.gif](https://www.s2ki.com/forums/images/smilies/redface.gif)
![rolleyes.gif](https://www.s2ki.com/forums/images/smilies/rolleyes.gif)
![cry.gif](https://www.s2ki.com/forums/images/smilies/cry.gif)
Worst case, drill out the bolt. Use a drill bit about the same size as the shank and when you get a few mil in the head should snap off. Then you can either remove the sump and get some pliers on it (it won't be tight any more), or use a smaller drill bit down the center of it (it's hardened on the outside but has a soft center) a few mill. Then force an allen key in and undo it with that.
![](http://s2000.byteserve.com.au/images/hacked.jpg)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
vise-grip will work.
While your at it, replace it with a fram-sure drain thing. Or that other thing that rick's accessories has i think. Where you can basically change the oil without any "tools" to mess up the bolt.
With my prelude, on the type-SH model, you can't fit a socket-wrench onto the drain-bolt because the ATTS unit is blocking it. Now I just use a fram sure-drain and I can drain the oil by screwing the attachment on.
I ended up stripping the damn bolt with an open-head wrench and I couldn't get it off. There were still enough "edges" to use a hammer though. So basically I took a hammer and a flat-head and started hammering at it to loosen it.
If you've messed it up enough to the point where there's no way a flat-head will break the torque on it, then get a vise-grip. Those things will NOT let go. And use your body weight to break the torque.
Pickup a cheap torque wrench as well so you don't do this again. A slightly inaccurate torque wrench is better then none at all. All you need is the flex type that costs a few bucks.
