damn headlight conversion
can anyone post any pics and instructions on how to perform the headlight conversion from 00-03 to 04 setup. i know the earlier ballast only seems to line up in one corner on the bottom of the o4 headlights, but i'm stumped otherwise. also i could not get the black plug from the ballast into the circular whole in the bottom of the 04 casings.
any help would be great.
sorry i dont know the answer to your questions but i did order the 04 headlights and 04 ballasts, harness, ignitor and it should be here in a week. hardtopguy told me i was the first pre 04 to order 04 ballasts so ill let you guys know if its all plug and play. hopefully it will be so i dont have to splice any wires.
Search retrofit. I can't tell you the exact thread but I did this last night. Found pics, instructions, pitfalls and everything else you'll need to know?
Cameron
good luck and keep me posted as to your progress.
Cameron
I would leave them alone and stick with your 00-03 before you jump into this project. If you have the 04 ballasts yada yada yada its an easier procedure. I have all the 04 hardware now and without it, it was a 4-5 hour install job with fabricating a bracket to make the 04 headlamp work with the 00-03 ballast. With all the correct hardware it should be a 1-2 hour install. Another S2k member here in Hawaii has the 04s with all hardware and has for months now. He said it would be a lot easier doing it that way so I went the other route then changed over once my 04 ballasts got here a month ago. BluredS2k, I dont wait, AJRacing, Spoonus, and myself have done the coversion already with and without the 04 ballasts and hardware. Just pm me if you run into problems.. I also kind changed my fronts. I took out the parking lamps. Thought they were useless. Let us know..and good luck..
[QUOTE]Originally posted by J'sAP1
thanks in advance!
Try PM'ing AJ_pwr he's done it to his or do a search for "2004 conversion part 1" or something like that. I'm still waiting for my headlights and I'll post about how easy/difficult it is to install.
j'sap1, so are the 04 ballasts plug and play to pre 04 cars? or will i have to splice some wires??? or just tell me which one of the people you mentioned has 04 ballasts so i can just pm them.
