Cruise control clutch switch
Old 10-15-2024 | 10:14 AM
larry resnick's Avatar
Default Cruise control clutch switch
The plastic piece that the clutch pedal hits when the clutch is engaged has broken and now the cruise control won't engage. What is necessary to replace the broken plastic part so the cruise will work? Thanks
Larry
Old 10-15-2024 | 10:18 AM
thoiboi's Avatar
Amazon Amazon
Old 10-15-2024 | 12:34 PM
Thanks for the information. I appreciate it.
Larry
Old 10-16-2024 | 04:44 AM
Chuck S's Avatar
While you're under there replace them all. I recall there are 3 (4?). It may be easier to remove the pedal assembly from the car and work on the workbench. Removing the drivers seat will provide more room.
-- Chuck
Old 10-19-2024 | 07:46 PM
Avionics86's Avatar
You can use a long pick and feed it to the hole.
williamb81
11-19-2021 11:24 AM
cjts2000
06-28-2018 11:18 AM
Brndon
02-11-2013 02:17 PM
Working_Class_S
02-29-2012 04:13 PM
Venom
10-20-2001 10:13 AM
Quick Reply: Cruise control clutch switch
