crashed s2k need help asap
ok so i have an 2001 s2000 and i hit someone then someone hit me the airbags blew out, now the motor wont start...theres no damage to motor it looks fine the core supports not touching the motor or anything nuthing got pushed against the motor. Now people have told me the the ecu needs to be reflashed in order to start is this true or is there something else wrong with it?
also ECU needing a reflash sounds unlikely. 2001MY don't have a programmable ECU which = not able to be reflashed.
ok well what could it be then? has anyone wrecked their car and had to reset something? would it be the srs unit needing to be reset? its not like the car is turning over but not starting, theres no noise or any clicking sound the dash lights turn on all power works thats why i thought maybe you have to reset something after the airbags blow out. i want to fix my car cause it olny has 26k miles on it.
I think the ecu kills the ignition and fuel when deploying the airbags. You probably have to do something about the ecu. Safety stuff to prevent fires or explosions.
This isn't s2000 specific, all modern cars have this. I am 99% sure this is your problem.
ultima4300
05-03-2016 11:39 AM
