Cp-035
Cp-035
A while back a few people were asking about CP-035's for the S2K. Some people said that they would fit, others said that they would not. Either way, here are some specifications:
Front, 18 X 7.5, +51mm
This combined with a tire that is 225/40, will yield an overall diameter of ~25.09 inches.
Rear, 18 X 8.5, +51mm
This combined with a tire that is 255/35, will yield an overall diameter of ~25.03 inches.
The wheel sizes specifications are straight from Racing Hart. The tire dimensions were used as an example so I could calculate overall diameter.
So, now that we're armed with a little more information, do you think go or no go?
Knowledge,
These are good sizes. They are close to the specifications I am running...
Front, 18x 7.5, +48mm
Rear, 18x8.5, +50mm
My car is pretty low, so I am using 215/40/18 and 245/35/18.
I'm sure if you don't slam the car, you can run 225/40/18 and 255/35/18. I plan on using these tire sizes on my next tire purchase...I have coil overs so if there are any rubbing issues...I can raise the car a bit.
Great choice in wheels by the way...I love them!
Rear, 18x8.5, +50mm
Here's the thread where this was discussed.
https://www.s2ki.com/forums/showthread.php?...highlight=cp035
Wow, I called Racing Hart last week and told them what diameter and width I wanted. The gentleman I spoke with asked what car it was for. I told him and he said, "For 18 X 7.5 and 18 X 8.5, the offset is +51mm." I verified that the offset he told me was correct for a S2000. Damn, I wonder what's up.
Okay, here's what Nat at Dazz just told me.
The CP-035's are available in both 18 X 8.5 and 18 X 7.5, however, that is only for 4 X 100 bolt patterns. In other words, it won't work on the S2K.
The CP-035's are available in 17's for the S2K, as stated in the other thread.
In about two months, the CP-035's will be available in 18's for the S2K.
[QUOTE]Originally posted by Knowledge
[B]Okay, here's what Nat at Dazz just told me.
www.hartwheels.co.jp
I've done this before, but here goes:
17"
7.5" - +48
8" - +45
8.5" - +40
9" - +63
9.5" - +43
...and my question was... would the 17x9 +63 fit?
17"
7.5" - +48
8" - +45
8.5" - +40
9" - +63
9.5" - +43
