Correct me if I am wrong but
Old 09-21-2006 | 05:41 PM
Homan's Avatar
Default Correct me if I am wrong but
Shouldn't Koni Yellows come in a yellow box?
Did I just get send wrong and damaged struts?
Old 09-21-2006 | 05:49 PM
S2kracka's Avatar
thats the right box, aslong as there is no damage to them put them on.
Old 09-21-2006 | 06:11 PM
turbo_pwr's Avatar
couldn't you just match the part number?
Old 09-21-2006 | 06:13 PM
Boofster's Avatar
Those are the correct boxes. My box was red too but the shocks themselves are yellow. Not sure about the damage.
Old 09-22-2006 | 01:00 AM
SpitfireS's Avatar
Koni Yellow in a red box is correct
(it's about the part #)
Front left: 8041-1278L Sport.
Front right: 8041-1278R Sport.
Rear: 8041-1279 Sport.
(that is what I see on your damaged box too )
Make sure the adjuster turns.
You could test the rebound adjustable damping by compressing the shock with the adjuster fully closed and then slowly opening it up.
Also, check the bottom brackets.
They should be parallel.
Make sure they are, otherwise you may strip your bolt.
The bolt should go in with no problem, with the shock on the workbench.
macr88
Electronics
01-18-2010 12:57 AM
macr88
Drivetrain
01-18-2010 12:43 AM
lil dog
05-14-2008 12:15 AM
Psilos
Κινητήρας - Μετάδοση - Περιφερειακά
03-15-2007 06:04 AM
Quick Reply: Correct me if I am wrong but
