Comptech Supercharger Owners: PLEASE READ
Hey SS if you want some free fractional metallalography done send me a PM. This will tell you if it was a pre-existing weld or bend flaw of a cyclic stress failure.
P.S. It's nice to have friends...especially if they know the folks that own Halama Ranch.
Update for you all, Shad replaced both of my brackets and front plate. We went back to the check valve version 3.10 for the next few weeks. The reason for that is to reduce all variables, I was previously using the Ghostbooster. So far so good (no hesitations).
We still do not know why dave and my brackets broke.
my front bracket broke ?monday (last time i drove). noticed it this AM upon inspecting for crack. its on the drivers right.
i will test drive tomorrow, i'm still planning to drive it to and at thunderhill this wednesday......any thoughts???
Boy, it really sounds as if there are a lot of harmonics going on in the supercharger system that Comptech hasn't figured out yet. I do a lot of vibrational analysis in my job, and it is amazing what harmonics can do, even 3rd order or higher. They can destroy some pretty strong components in a matter of minutes.
Hopefully, Comptech will get to the bottom of these problems.
I thought this thread was totally DEAD...well since it is been resurrected I will throw my .02 in.
First off, after a year of testing many different setups without success Comptech finally made a decision to soften up the mount setup by incorporating rubber isolated mounting points. As of today there are 3 cars with this setup and I will say it is VERY NICE. The vibrations are virtually non-existent, I still do feel a slight vibration between 4.5-5K. But compared to everything I have tried this is by far the best setup I have tested. Therefore, the harmonic issue should be eliminated. (crossing fingers)
When you say drivers right I am assuming it is on the passenger side of the motor which would mean the VTEC bracket. As long as you are not leaking oil you should be fine. You may want to give Comptech a call. They are kind of on the way to Thunderhill so you might be able to get something before the event.
BTW, i just re-read your post and is the front plate cracked?? If so you should not have any problems driving it like that for a little while. Both dave and I have driven on the track with cracked front plates. Just keep an eye on it .
I have driven many hundreds of miles with cracked brackets and have done track days that way as well.
txst-We believe this lastest revision will be the final product. .
Originally posted by rocketman
this will be a no cost "product update"?
