comptech supercharger
i wanted to get a comptech supercharger aftercooled for my04, but i was wondering if there was other stuff i needed to get for it to be running well?
and whats the standard boost at?
thanks
thanks
quick and easy answer is nothing else is needed. long answer is use the search function. 6.5psi pulley comes with the kit, and if you get the ac, you'll lose appx. .5psi.
So an A/C will give slightly less power ?? this is confusing
no. you will lose boost but you gain from the cooler air going into your motor. the kit comes with everything you need. there are products that are recommended when you get your kit such as a clutch, reinforced diff, gauges, exhaust, ect..
i am very pleased with my comptech kit and highly recommend it.
MAtt
MAtt
Slightly off topic
Will the whole kit (S/C and A/C) fit on a RHD S2000 having battery and brake stuff inverted ?
Am looking to it as being my next $$$ mod if it fits on RHD and finally my insurance will allow.
Any ?
Any ?
regardless of what # they say the pulley is, in straight bolt-on form, you will only get 5 pounds of boost (maybe 5+) with aftercooler.
i got 5 pounds.
i got 5 pounds.
Originally Posted by AusS2000,Oct 22 2004, 02:14 PM
Hmmmm...
Note: I don't have the AC and I had to relocate the FPR to the front crossmember. I just modofied the bracket and mounted on the existing hole for the stock air box. If you had the AC you may have to find somewhere else for it.
I've since removed the FPR altogether and gone for an AEM EMS and larger injectors and a few other mods. Must get a more recent picture.
Where are you from BTW? RBT? Is that Kenya?
I just looked up the Flag and it's Malta. Correct? Have some good Maltese friends here in Sydney and I even went there when I was about 2.
Re-allocating the FPR is a simple mod to do i guess.. Next stage will be my insurance..Third will be my wallet.
Yes I do live in MALTA Thats a very long way from sydney.
BTW.. RBT stands for the town RABAT. not kenya..
EDIT: one other thing. Was the air box hard to install as I have some cables running there.
duff0000
Forced Induction For Sale
08-18-2012 09:04 PM
