Clutch Slipping! Ideas Please
That's the thing I like about Honda Engineers, they're thoughtful.
And they don't suck.
You can pretty much count that they didn't leave a whole lot of performance left on the table and that everything is engineered to work together.
When you start changing things, you have to change a LOT of things in order to actually make an improvement.
Ebay coilovers, cold-air intakes and pulling ABS fuses aren't going to do much to improve performance.
Clutch delay valve falls under that umbrella.
Originally Posted by my_slow_2k,Nov 8 2009, 04:35 PM
So if upgrading to a stronger PP helps alleviate this problem, what are the advantages, if any, would there be in adding a lightened flywheel? If there are no real advantages to a lighter flywheel and a stronger PP is the only addition, is the delay valve still needed, or could it be taken out with no ill effects? Or if it were left in with any combo of heavier duty PP/flywheel would there still be a slight delay as a result?
Just trying to pick your brain for knowledge, not questioning your post.
The AP2 flywheel is 10 lbs heavier sitting on a scale. Spinning in the transmission, the weight increases exponentially, and the pressure plate is what dictates how strongly the friction plate can grab. Afaict, Honda added a heavier flywheel to better keep rpms up between shifts, but neglected to compensate for the increased rotational mass with a pressure plate that exerts more force on the friction disk. The CDV has nothing to do with this engagement - fast or slow, if there's not enough pressure, you're going to get slippage. The CDV is fast enough to minimize both shock and slippage, which is what its designed for - removing it will allow you to engage the pp faster, but if it can't stop the flywheel, what's the point?
Afaik, Billman250 and S2oooNvegas probably have the most hands on time with S2000 clutches, and they both agree that the pressure plate is most likely the issue. As well, I've talked with many owners that have removed the CDV and admit it doesn't help with slippage even if things feel quicker.
Look at some of the things Honda changed about the drivetrain - bored engine with revised VTEC and cams so there is real power below 6k rpm. Heavier flywheel to assist with keeping rpms up between shifts. CDV to reduce shock to the driveline and protect the diff. Why not a stronger pp though? I think its an oversight by Honda that it was never beefed up.
Originally Posted by carrera0to60,Nov 9 2009, 12:00 PM
Well I think I come to the realization that my technique isnt that great....hard to admit. This weekend I went out for a drive just to see if I could change how I shift. Just giving it that extra millisecond in between gears and it never slipped. My main problem is that Im coming from an AP1. So I drove that car like that for 3yrs and never had the clutch slip but now after all this info I didnt know it makes sense. I guess this is a good lesson to learn now before I go FI and then really do some damage by trying to chirp the tires. One more thought, since the CDV was getting in the way of my "superior" driving skill and not allowing me to chirp the tires I decided it had to go. I think this maybe the case for why it was deemed evil.
The AP2 uses heavier components and you can't move them as fast. Take a chopstick in your hand and you can wave it back and forth quickly. Try the same with a hammer, and you'll notice you can't wave it as quickly - same basic concept with the AP1/2 transmissions. The CDV is like a ring on your finger - it doesn't effect your ability to wave. The AP2 still needs a stronger pp though.
I agree, great information. I have removed the CDV, it does seem to "help" slightly, not the improvement I was hoping for, in my case though, as well with my MY06, I think its more of the DBW.
I hadn't really given too much thought to a different pressure plate until now.
