Clutch change??
Old 06-16-2003 | 12:18 PM
S-ToDo's Avatar
Default Clutch change??
Hi folks.
Just wondering anybody know when should I change the clutch??
How is the clutch feel like when your clutch is wearing out.
please give comment
Thanks
Old 06-16-2003 | 03:07 PM
wanabe's Avatar
when the mechanic says too?
it will get slippery (wont engage properly), or noisy, or both...
if really bad, you wont be able to get into gear-
what are your symptoms?
Old 06-16-2003 | 03:38 PM
mustangkiller's Avatar
when you try to pull out or give hard throttle the rpm's will climb but you wont pick up any speed thats one symptom
there is an inspection cover on the bottom of the bellhousing if you pull that you can check it
Nemi
05-26-2014 07:56 PM
kidtwist
02-26-2010 01:55 PM
huyman
09-14-2008 11:47 AM
scguy
11-12-2004 04:33 PM
dundonr
09-02-2003 09:41 AM
Quick Reply: Clutch change??
