Clicking Noise. Weird.
Old 08-23-2006, 06:39 PM
radtech's Avatar
Default Clicking Noise. Weird.
Can anyone help me with this. I can hear a clicking noise coming from the rear end. It's not suspension related, well I don't think. It seems to happen when either up or downshifting or even just taking off in first. It literally sounds like a clicking noise. What can it be. Should I be worried.
Old 08-23-2006, 06:48 PM
__redruM's Avatar
Details? Single click, or rythmic. If rythmic does it vary with car speed, engine speed or not at all. Could be anything from a CV joint to a cooling exaust. How loud, how often?
Old 08-23-2006, 06:52 PM
radtech's Avatar
It sems to happen at very slow speeds, like just taking off. It's almost sounds like someone clicking a switch or something. It happens all the time but it's not continous, just a single or couple clicks. It's not even consistent. It seems to be related to the clutch or something. It's really weird and noticeable.
Old 08-24-2006, 06:40 AM
__redruM's Avatar
Sounds like a relay or something from your description. You might have to wait for it to get worse to get a diagnosis. Mechanics hate intermitent problems. Just guessing:
Exaust ticking
CV joint (are the CV boots solid?)
Something in the rear or connected to the rear end
Brake light switch
Fuel pump relay?
Good luck...
Old 08-24-2006, 07:56 AM
R11
R11's Avatar
If this is occuring when you are "just taking off" as you say and you happen to be turning at the time, (like out of a driveway or from a stop sign at an intersection for instance), it's just the LSD rear end and is completely normal.
ron
Old 08-24-2006, 07:58 AM
str8 6's Avatar
rear brakes. right after you reverse and go back into 1st. that's my guess.
Old 08-24-2006, 09:06 AM
NNY S2k's Avatar
Maybe this?
https://www.s2ki.com/forums/index.ph...&f=22&t=412532
Old 08-24-2006, 09:21 AM
FISH22's Avatar
retorque the axle nuts to 220 ft lbs. thats it!
Old 08-24-2006, 10:22 AM
__redruM's Avatar
Originally Posted by NNY S2k,Aug 24 2006, 09:06 AM
That sounds like the ticket, what year S2000 do you own?
Old 08-24-2006, 10:38 AM
PrimoGen's Avatar
Go with the axle nuts fix first......I have never heard an S without this clicking sound.
Quick Reply: Clicking Noise. Weird.
