Checking Oil Level
Old 04-13-2001 | 08:08 AM
gbaker's Avatar
I have found that the most reliable way to check oil is to:
1. Let the car sit overnite(or at least several hours).
2. Remove the dipstick wipe clean and reinsert.
3. Repeat several times until a consistent level shows up.
It seems that the tube the dipstick travels through collects drops of oil somewhere. These drops seem to get deposited back on the dipstick, giving a false reading, until I repeat enough times to clear them out. Am I wrong? Seems goofy.
Is this how others do it?
Old 04-13-2001 | 08:16 AM
S2k Dude's Avatar
Thanks for the tip but I would hope everyone is doing this already. If you don't repeat the process a few times, how would you know your reading is accurate? But I guess that's your point.
Amazing amount of discussion on how to check the oil...
Old 04-13-2001 | 08:24 AM
VA S2K's Avatar
Yes it shouldn't be this hard to read the dipstick but it really does NOT read very well. The last time I added oil to the engine I checked the level no less than 10 times allowing several minutes between checks until I got a consistent reading. Can be a pain in the a** sometimes!
joe_s2k's Avatar
You must not be as confused as the rest of us. I get a different reading each time on each side of the dipstick. This is a strange car...
Old 04-13-2001 | 09:09 AM
MarkS2K's Avatar
Sometimes, the dipstick doesn't want to go back in, and I always get different readins on each side of the stick.
Old 04-13-2001 | 03:09 PM
John David's Avatar
When checking the oil try not to let the stick touch the side of the 'tube' that it sits in. I have found I get a more accurate reading by being very careful, and pulling the stick sraight out. But yes, I still check it a least twice and I think it is a good habit to check, re-check, and check again. I hope everyone is doing this.
Old 04-13-2001 | 09:06 PM
S2WOOOW's Avatar
I've checked the oil right after stopping the engine. I actually hurried and opened the hood and checked as fast as I could to see the difference. I only got 0.5X lower than after sitting all night.
Old 04-13-2001 | 10:08 PM
aojo's Avatar
Geeze...thanks for the post. I was too embarassed to do so myself thinking I was doing something incorrect. The readings I get always seem to vary regardless of motor temp. My solution is to check every week and top off as necessary.
Old 04-14-2001 | 12:07 PM
wirejock's Avatar
Yep, that's about right. I check mine in the morning. I also stick and wipe and stick and wipe. Soound kinda like the directions on a shampoo bottle.
s2k_Doug67
11-13-2014 06:24 PM
TopGear
07-15-2009 04:51 PM
qbmurderer13
05-10-2008 04:46 PM
wang_uk
08-16-2007 02:09 PM
Skip
12-02-2003 08:03 PM
Quick Reply: Checking Oil Level
