Check Engine Light???????
Old 07-16-2003 | 07:46 PM
Blue Bitch 2K's Avatar
Default Check Engine Light???????
My car has 5100 miles on it and I was driving to work this morning and the check engine light came on? I stopped and checked the gas cap, and sure enough, some how it was loose. At least it became lose while driving because I always tighten the sucker. I tightened it up, but 12 hours later the light is still on all the way home from work. What can be the problem? Any suggestions???
Old 07-16-2003 | 11:08 PM
Boit's Avatar
Isn't there a reset? I seem to remember coming across the rest when reading my manual. I'm at work and can't check it for you.
Old 07-17-2003 | 12:46 AM
BillK's Avatar
Depending on how Honda programmed the ECU, the CEL will either need to be reset by your dealer or it will go out by itself after a certain number of start cycles without the fault recurring (usually around 10 for most manufacturers.)
Old 07-17-2003 | 03:12 AM
brushman's Avatar
-CLICK-
Commonly Asked Questions
https://www.s2ki.com/article/archive/4/
-CLICK-
Troubleshooting
https://www.s2ki.com/article/archive/15/
-CLICK-
Resetting the ECU/Check Engine Light
https://www.s2ki.com/article/articleview/5/1/15/
FYI:
will answer "almost all" basic S2000 questions and show you step by step how to do "most basic" (even some hard ones) maintenance functions.
acklavidian
09-10-2013 05:58 PM
reviano
03-05-2006 10:03 AM
IBMcpa
03-08-2005 10:14 AM
news2kroller
07-13-2004 10:06 AM
yogi
11-06-2000 04:24 PM
Quick Reply: Check Engine Light???????
