Chatter in 2nd and 3rd gear when decelerating
I have searched the archives and found that there is a TSB for this specific problem. The solution is to replace the clutch disc. Now is this covered under the factory warranty or will I have to pay for this fix out of pocket.
Another problem I see is the rear vinyl window is starting to leave a crease. Am I just SOL?? My warranty will expire in about 2000 miles.
What should, could I do to fix these problems??
You should schedule an appointment to have your clutch disc replaced asap! Regarding the window, you may be SOL. There have been a couple people that have gotten their dealer to replace it under warranty...but don't count on it. Do a search for more info. I'm planning asking to get my rear window replaced uner warranty before it's up...
Good luck.
Good luck.
you shouldn't have to pay for anything. I would highly recommend changing other parts while the car is being repaired. If I would have known that the car was going to be down for 2 days, I would have ordered a lightened flywheel and possibly a different pressure plate. I didn't know, but next time i will
hansai00
07-15-2008 07:49 PM
DC2SpecR
11-24-2002 04:53 AM
