Chassis Stiffening Components
Old 03-21-2006 | 08:50 PM
IIGQ4U's Avatar
Default Chassis Stiffening Components
I don't know if this is in the right area or not but I was wondering what front end chassis parts you recommend to reduce oversteer in the API.
Do you recommend one of the X Brace units with an upper tie rod?
What do you all suggest?
I appreciate any assistance.
Old 03-21-2006 | 11:06 PM
aronparsons's Avatar
A larger front sway bar will reduce oversteer at the limit. There are a few non-adjustable ones that will suit you fine for street driving. If you're looking for a solution for autocross, there are three choices. A search on "sway bar" should give you all the reviews and such you need.
A better solution is to take yourself to a performance driving event/school and learn to drive the car correctly. Avoiding bad inputs (driving errors), you will learn to not make the common mistakes that lead to undesirable oversteer.
Old 03-21-2006 | 11:51 PM
Emil St-Hilaire's Avatar
S2K is a pretty neutral car.
Old 03-22-2006 | 03:52 AM
slimjim8201's Avatar
1. Stiffening the chassis will not reduce understeer.
2. Our suspension does not use a sway bar. I think that term was last used around 1975. The correct term is anti-roll bar (ARB).
3. Stiffening the roll-rate in the REAR of an already neutral car will make it tend to oversteer more. Stiffening the FRONT will induce more understeer.
Old 03-22-2006 | 05:35 AM
Just stiffen both ends;get the Muz sway(ahem..Anti-roll bars)bars.
Old 03-22-2006 | 06:04 AM
IIGQ4U's Avatar
So those products from Prestige are pretty good pieces eh? I will probably do that and then perhaps enroll in class or auto x event.
Thanks a lot.
Old 03-22-2006 | 07:01 AM
Thanks a lot.
Enroll my friend;that's the best thing,that can happen to your "S".
whitt1
03-30-2010 12:46 PM
s2krev
10-30-2009 08:25 AM
Amer
09-06-2006 09:35 AM
Stw000
02-16-2005 01:29 PM
t.c.
01-15-2003 02:39 PM
Quick Reply: Chassis Stiffening Components
