Changing Transmission Fliud?
Does anyone know how to change transmission fliud? How do we add fliud into the transmission? In the service manual the bolts are horizontal? heh...*being a dumbass*
All the manual transmissions I have dealt with work the same way. You drain using the lower bolt, reinstall and remove the upper bolt. You pump in the new MTF (return the car to level if it was not to let the lube drip out to an even level) and reinstall the upper bolt. Takes less than an hour usually.
For a learning experience, I would probably take it to a shop and watch them replace the transmission fluid and the differential fluid.
You'll know the procedure the next time you need to do it.
