Center Console Disassembled
My quest to a revamped interior is on! Ill try to document as much as i possibly can starting with the center console
I currently in the process of moving a way from the tan to a more subtle/sport oriented interior
The before
The after
The before
The after
Also to note i wanted to fix my center console door not sliding whatsoever ever
Am i missing anything on the door assembly? I dont see anything that can actually retract the door to open
The gear that allows the door to slide in and out
Just a quick update!
I finally found the "spring" that helps the center console door retract
Found it after takiing the center console of to do some cleaning and refinishing
Good incentive to pull mine out and look for that spring......mine hasn't slid open properly for several years!!
The spring is an odd flat coiled clock spring. A thin, flexible flat length of metal that is coiled up like a clock spring. So if the springs connection to the door came loose, no more retracting
The door slides along tracks on either side. If something were binding, no more sliding door.
The leather fabric of the armrest can also begin to peel away, and can jamb up the door as well.
