Car shaking & check engine light turning on???
#21
Hi there,
Just for your information I would like to point you to another thread where the matter of misfiring is being discussed.
Although initially the error code I got strongly suggested 'misfiring' it turned out to be a clogged fuel injector...
See explanation here: https://www.s2ki.com/forums/index.php?showt...0&#entry4471437
Take care,
Siepel
Take care,
Siepel
#22
Wow, that *was* an old thread.
And I was wondering at the moment of clicking "add comment" how on earth it was possible that it was already the 20th of September, rather than the 18th here in Europe....
#23
Question:
To those that have had this problem (and resolved it with injector replacement or cleaning), is your car a daily driver or does it sit extended periods in the garage?
#24
Originally Posted by mxt_77,Mar 19 2005, 06:08 PM
Question:
Siepel
PS: ...waiting for the "this thread won't die" sign
#25
I had the same problem this past weekend after the car had sat for a couple of weeks. Very rough idle and actually stalled on the freeway in rush hour traffic shortly after the check engine light came on. I had to keep the car from idling for the remainder of the trip. The following day, I started it up, drove for like 15 miles or so and the light went out. The scary part is that the rough idle was very similar to when one of the spark plugs had burned out and scored the inside of the piston shaft causing a misfire. When that happened the idle problem was persistant and no check engine light fired. For me, there was never a warning light when the really bad things happened. Bad cat converter and O2 sensor...same thing.
Brndon
04-11-2013 12:34 AM
