car pushes to the left when gassed hard
Old 07-19-2007, 12:37 PM
dolebludger's Avatar
Question? Other than causing an air leak and low pressure, how would a nail in a tire cause the car to "pull?"
Old 07-19-2007, 12:57 PM
Fronks2k's Avatar
Originally Posted by RED MX5,Jul 19 2007, 12:28 AM
Common question. The cause is USUALLY uneven tire pressures. If the tires and their pressures are correct, then it's almost got to be alignment.
Check the tire pressure first. Air is free, but alignment cost, so try the free stuff first.
Air costs me 50 cents for 5 mins, the smartass in me had to make the comment .
Old 07-19-2007, 01:43 PM
5SAY307's Avatar
Could be that driver side is too heavy, if you have coilover setup, you can have it corner weight it with the driver in the car.
Old 07-19-2007, 01:49 PM
RED MX5's Avatar
LOL. You are being over charged.
Even if you do have to pay for air, alignment still cost a little more.
__redruM's Avatar
It wouldn't, unless it was a really really big nail. Letting air out is enough. It's certainly an interesting point, because the OP would fix the presure and 2 days later the car would pull again.
Old 07-19-2007, 04:58 PM
OK, I see. A slow leak such as caused by a nail could produce the problem. One thing I have learned about my AP1 is that you can't tell a low tire by looking at it. Once, I looked at one of my tires and thought it looked "a little bit low." I put the guage on it and it registered 0 psi! Our W rated (or higher) tires have very stiff sidewalls, and are very near "run flat." But of course, they don't perform very well at all that way.
Old 07-19-2007, 05:05 PM
__redruM's Avatar
I ruined a tire that way. Damn nail. I knew something was wrong, but waited until I got home to check the presure.
Old 07-19-2007, 05:08 PM
HondaS's Avatar
ya i have the same problem and its i think what onlyhonda4me said
cuz i just bought some racing harts and one wheel is from a diffrent mold and you can tell its a little bit wider.
Old 07-19-2007, 05:26 PM
madkimchi's Avatar
check your tire pressure!!!! i had same issues not long after my freaking tire ripped out like a donut. i realized my car was pulling to one side thought it was rain but wasnt' sure not even a mile later i saw my rear tire going faster than me and i had to pull over.
Old 07-19-2007, 08:29 PM
Elistan's Avatar
Originally Posted by N-motionauto.net,Jul 19 2007, 02:25 PM
it's definitely not the wheels or tires.
Why do you say that?
Quick Reply: car pushes to the left when gassed hard
