Can the odometer be tampered with?
Old 04-18-2006 | 11:48 AM
  #31
pdexta's Avatar
I had an idea a while back that would work depending on how drastic a correction the "yellow box" allowed for. You could leave the stock gearing, but install the yellow box and set it for a 60.9% correction factor. This would allow us americans to switch over to KPH, which would now give a correct MPH reading. By doing this you would cut mileage on your car by 60.9% (at 50,000 miles you would be reading 31,075! I'm pretty sure Uncle Sam would frown upon this idea though.
Old 04-18-2006 | 11:50 AM
  #32
F355FTS's Avatar
Yea i was just wondering if it was as easy as pulling a fuse.
I am a firm believer in the " Anything is possible" saying.
But sounds like its not very likely on a S2000
Old 04-18-2006 | 02:42 PM
  #33
sahtt's Avatar
It's pretty damn difficult to do if you aren't an electrical engineer or the like. The older style odometers that were just a set of gears are EXTREMELY easy to alter. I was actually very dissapointed when I realized how easy it was. By a fed investigation, 1 in 4 cars have odometer fraud. This would scare the $h*t out of me except most of these fraud odo's are done to much older cars [99k is a lot more appealing than 109k] with simpler guage clusters.
Old 04-18-2006 | 02:54 PM
  #34
littlerocket777's Avatar
I'm surprised no one mentioned the easiest way yet. Put the back wheels on jack stands, pop it in reverse and jam a stick between the seat and gas a la Ferris Bueller.
Old 04-18-2006 | 04:46 PM
  #35
530s2k's Avatar
There may be a simpler way- but I actually like where I'm going with mine....
What physically effects the VSS? I.e. Is it like gear with a magnet on it and an electronic pickup, or what?
Lengthen the wire on the vss, and hook it up to something that emulates whatever drives the signal on the car.
Obviously there's a simpler way to do this, but i'm obviously not an electrical engineer.
Old 04-19-2006 | 04:23 AM
  #36
vtec9's Avatar
well there is a difference between just slowing down the odometer and setting back/changing the count.
Old 04-19-2006 | 06:06 AM
  #37
Wisconsin S2k's Avatar
The VSS gets it's reading off the counter shaft in the transmission. It then sends an electrical signal to the ECU and then to the dash/odo.
Old 04-19-2006 | 10:34 AM
  #38
Kwyjibo's Avatar
yellow box only goes to 28% i believe....and if you could get it to 50%, then you could just double the speed in your head..at 5mph, your doing 10, at 30 you are doing 60....and you only rack up 1/2 the miles you drive.
but even the modifry yellow jacket goes to 25%.....now if someone knew how to wire two of them together and would PM me with that info, that would be awesome
it probably is doable to hide a few miles on the car, but i don't think it is worth the hassle....
EuroBoutique
01-04-2014 06:53 PM
WolfpackS2k
04-16-2010 02:07 PM
Grazhoppa
02-02-2005 12:11 PM
yellows2000
06-07-2003 12:26 PM
scottrnelson
07-26-2001 08:28 AM
Quick Reply: Can the odometer be tampered with?
