Can i Get some help with offsets?
Old 10-15-2003 | 05:12 PM
oneboy2c's Avatar
Default Can i Get some help with offsets?
Can anyone help me and tell me the offsets for our car. I am get 18" int he front and 19" in the back. I am having the machine shop shave the rim to the right offset for me. Any help would be appreciated.
Old 10-15-2003 | 05:14 PM
ASMspec's Avatar
+55 fronts and +65 rears...
Old 10-15-2003 | 05:30 PM
oneboy2c's Avatar
Thanks jdms2000. Do all rims uses the same offsets?
Old 10-15-2003 | 05:32 PM
JL9000's Avatar
No.
Old 10-15-2003 | 05:36 PM
ASMspec's Avatar
No they dont. They are shaving the rim? Why not just buy correct offset wheels?
Old 10-15-2003 | 05:40 PM
KIDS2000's Avatar
Oh here is a brief tutorial on offsets ofthe car
Stock now you are running
16x6.5 +55
16x7.5 +65
2 main things to consider. Wheel Width and Offset.
OK, Assuming offset is the same....
Say you get 1 inch wider wheel for the front. 18x7.5 Take that 1 inch divided by 2 and add that value to both inside and outside of the wheel to estimate how much the wider the wheel will come out by.
Different offset.
Now you are using 16x6.5 +55
Say you have the same wheel width but with +35 offset. That just means the wheel is 20mm (55mm-35mm) outwards from the hub.
So yeah do your homework and decide how u want the wheels to look in relation to the car body. Dont let the shop decide which offset is right for you. You paying big $$$ so get it done exactly how you want it...
Old 10-15-2003 | 05:57 PM
oneboy2c's Avatar
i am getting 19x8.5 5x114.3 - Offset 38 for back and 18x8.5 5x114.3 - Offset 38 for front. 225 in front 265 in back. Can anyone tell me what offset this should be shaved to.
Old 10-15-2003 | 05:59 PM
turbo_pwr's Avatar
Umm am I wrong or is there no way in hell that would work. You need to go + in offset not minus. Wouldn't shaving the rim make it even lower?
Old 10-15-2003 | 06:01 PM
oneboy2c's Avatar
i am getting a pair of rims i like and i am kinda set on those rims for my car.
oneboy2c's Avatar
Or do i need to use spacers?
