A/C question... how often to run it if you dont use it
i have had the car for almost a year now... never have used the a/c, except a few times to test it.
i was told by a friend that i need to run it fairly often to protect the seals. he did not know how often to run it to protect it.
anyone know how often it needs to be run to maintain it?
Wanabe, I'm in the same boat as you. I mainly keep the top down so what's the use of a/c?
The only time I really use it is when it is raining and the top is up. I use the a/c to stop the inside of the glass from misting up.
Having said this, I am not experiencing any problems (i.e. it works effectively) on the rare occasions on which it is used.
Originally posted by pwalker
I think you would be okay running the A/C for at least 20 minutes once a month when not used regularly.
I remember reading a post saying the S2K was designed to let you run the A/C with the top dowm. I used it today for at least 50 miles (the outside temperature was probably in the 90's), and it certainly kept my feet nice and cool. I think you have to set the vent switch to the "recirculate" position.
Quote the the S2000 Manual
Run the air conditioner at leastonce a week during the cold weather months. Run it for at least ten minutes while you are driving at a steady speed with the engine at normal operating temperature. This circulates the lubricating oil contained in the refigerant.
This should also apply Year round.
Axcilla
Axcilla
The AC is important for any high-humidity conditions, even in the wintertime. Set your mode control to defrost and you'll notice your AC light comes on (regardless of temp setting) to aid in de-misting the interior.
Gatsbee13
15
05-18-2009 08:51 PM
