Buying a 2000 s2000
Buying a 2000 s2000
Hey guys! I'm going to be a new (to me) S2000 owner, I found an extremely clean s2k with 49k miles on it. I'm just wondering if there is any major maintenance coming up I should know about? Clutch, timing chain, etc... I have read over some other posts, but haven't really found anything definitive.
If possible, test drive it or let the owner drive it, to make sure the clutch isn't slipping. I have 102k on mine and its running strong. If it is skipping, use it as leverage.
Check if you can, if it has had the valve clearance done, & do them if you can't find when they were done.
The same with the fuel filter.
I was lucky enough to find a 2001 a couple of years ago with only 27,500 Kilometers on it.
As with you, I changed all fluids, the fuel filter, pollen filter, & did the valve clearances.
It is now coming up on 40,000Km, & has been a total joy.
Hope you're as lucky, & have as much fun
