burned bulb?
burned bulb?
so after lunch i go turn my car on and i see that part of my dash is darker than the other. i turn of the ignition and turn in on again to see if it would light up. didnt work. i turn the headlights on and it gets even darker. i am thinking of the LEDs on the back has blown and i will need to replace it. has any one else had this problem before? here is what it looks like.
Yes, it is burnt out. Its not an LED but an incandescent. You need to drop the steering wheel and pull the IP out to change that bulb, so if you want to change it, replace all the bulbs while you have it apart.
