Broken plastic under the pedals? Car won't start
Old 09-03-2022 | 11:05 AM
fxs2000's Avatar
Default Broken plastic under the pedals? Car won't start
When I press the start button nothing. Everything was fine a day ago. I found this plastic pieces under the pedals. Does anyone know where this come from. I check everything, fuses, battery, everything is fine. The dash lights up as normal. It is just nothing when I press the Start button.
Old 09-03-2022 | 11:07 AM
spider2k's Avatar
Clutch switch?
Old 09-03-2022 | 02:53 PM
Car Analogy's Avatar
Clutch interlock switch. You can temp bypass switch with a paperclip to be able to start it.
Replace plastic pad when you can.
The following 2 users liked this post by Car Analogy:
spider2k (09-03-2022), stock06 (09-03-2022)
Old 09-04-2022 | 07:16 AM
fxs2000's Avatar
I found the clutch plastic piece on the mat this morning, it looks white. I'm still not sure where that black spacer in the in the picture above comes from. Thanks guys!
Old 09-05-2022 | 08:33 AM
cosmomiller's Avatar
I believe the part is identical to Honda manual cars but has a different part number for the S2000. If it shows unavailable, ask a dealer to see if they have the one that matches for another Honda Car.
mcraw152
09-24-2020 12:44 PM
topDown99
05-16-2019 07:23 PM
matt0488
03-21-2015 03:02 PM
only9k
03-18-2015 08:52 PM
prorcracer87
16
09-15-2007 02:15 PM
Quick Reply: Broken plastic under the pedals? Car won't start
