Brake Rotor Rust
Brake Rotor Rust
Has anyone tried to remove the Rotor Rust from the brake rotors with "Skyco OSPHO?
It works on rust by chemically changing the red rust color to black.
The rust on my rotors and rims after washing is driving me crazy.
Does anyone have any other ideas?
Thanks for the help,
Larry
Larry
It works but the rust will be back. I have found that header paint (1300F silver) works best. If you go to the track the shiny top layer cooks off but enough stays on to prevent rust. For street use it is fine. My current rotors were cad plated that did not last; frankly I think the paint held up to track heat better.
Originally posted by cdelena
Perhaps you did not do a through job, as I have had better luck than that. Ideally they should be removed and thoroughly cleaned and dried before being masked and sprayed with three light coats of header paint. After installing they can be heat cured using the heat the brakes make. Mine looked great with months of street use and only dulled with the heat of track use.
I assume we are talking about rust on the edges and vanes. Of course the swept area will rust (like most cars) but gets cleaned off with a brake application. The '02 we looked at recently appeared to have some sort of treatment on the rotors.. does it not reduce rust?
Thanks Guys but I bet there is a easy way to coat the rotors with some type of heat paint that will hold up. I think I'm going to try ONE first by treating it with the OSPHO rust removal/coating liquid and then use the silver Header paint cdelena indicated.
Larry
Larry
Affordable cross drilled rotors...now THAT is a mod I'm interested in. It's crazy to spend two hours detailing a car, go back inside to eat a sandwich and come out to see that mess.
