Brake didn't function properly.
With the vibrating sound, did you feel it? Most of the time you will feel the abs working through the brake pedal.
Also did you really mean to type 10km/hr? That doesn't seam possible as that is only around 6mph at which speed the anti-lock brakes would be impossible to evoke unless you are on a frozen lake.
one thing i've noticed and heard a lot about from others who driven my car is that although the S2000's brakes have a quick initial bite, like any other good sports car such as a Porsche, you really need to stand on the pedal in order to get max braking.
THe pedal has a very firm action, and you need to be forceful with it when calling up max braking.
I don't know... With no brake idiot light it's not the reservoir level that's the problem. I'm betting he just hit ABS because of road conditions. You combine that with low temperatures when the tires get hard, and it's not surprising.
Bubbles in the brake lines could make the pedal spongy, but shouldn't have caused shuddering like he described.
Oh, and I love the S2000 brakes.
Yeah, I didn't consider his location, and he didn't give any info on environmental or tire conditions, if it was cold and wet (or even icy) and he was on summer tires , he could have just been sliding along with zero traction with the ABS pumping merrily away.
Though if he couldn't recognize this I think he really needs some driver's education or he's headed for (more) trouble.
How about it TaeHwan? was it cold and wet? Could there have been ice or oil on the road? Have you ever hydroplaned a car? (not that you did in this case, 10km is way too slow to hydroplane in any amount of water). I have no intention to offend you, but I think if you have only a little driving experience you should look into taking some courses or joining an autocrossing club or something of that nature. At least get out somewhere SAFE and prectice sliding the car around at the very least.
Apparently a common reaction for people who've never experience ABS is to get off the brakes when they start pulsing. That's why I make my wife lock up a new car a couple times so, she can feel what it's supposed to feel like in a panic stop.
Originally Posted by CaptainMike,Nov 14 2006, 10:27 PM
Saki, He said
"I had a huge gap to stop the car with no
problem. I started to put pressure on the brake pedal like always.
But then, it felt different; it was too cushy, and the pedal went in deeper
than it should and heard this vibrating sound(someone said it's ABS...?)
and the car did not stop and kept on going."
If he couldn't stop the car within a "Huge Gap" from 10km/hr there is something wrong with his brakes. Unless he was on an oil slick.
To the OP, your car is under warantee, if your brake fluid is low, you may be able to get your brakes working by adding fluid, but if you have a low fluid level there is probably some reason it is low, likely a leak in the system somewhere. Take it to the dealer. Don't drive it without reliable brakes so have it towed if you have to.
