Blown Motor....What's it worth?
Old 04-15-2012 | 04:43 PM
  #31
rob-2's Avatar
Originally Posted by Jamie_Murray
Originally Posted by rob-2' timestamp='1333578939' post='21576744
[quote name='fr4n' timestamp='1333531456' post='21574099']
Can I ask. What on earth did you do to blow a Honda engine
Most likely, he or a previous owner overreved the motor and damaged a retainer. This doesn't always cause a valve to drop at the time, but can stay hidden until the valve finally drops. Than you basically ruin the block and often the head in the process.
Ap2 motors have tougher retainers. If you never overrev your motor it isn't an issue.
That's part of the reason I'm irked about the situation, I had owned the car for three years and only been able to put five thousand miles on it due to paperwork issues. I finally get the car on the road and after the first week it drops a valve. I'm not some punk out here bouncing off the rev limiter and shifting from 4th to 2nd, I'm a competent racer who understands the mechanics of the vehicle, Always heel-toe, and had never missed a shift.
[/quote]
I wish I could have told you to get the retainers changed out. It would have saved all this trouble and cost. I also wish you had contact as Honda who could have helped you out.
Old 04-16-2012 | 02:50 PM
  #32
Zed03's Avatar
How in the world does hydrolocking blow an engine?
Old 04-16-2012 | 05:02 PM
  #33
NDAZONE's Avatar
It depends on how many overnight parts from Japan you still have installed on it.
Old 04-16-2012 | 05:16 PM
  #34
rob-2's Avatar
Water doesn't compress much, so typically a hydrolock damaged motor is done on 'restarting' where the piston is slammed into water typically breaking a rod, bearing or the piston head itself.
Old 04-17-2012 | 06:58 AM
  #35
deepbluejh's Avatar
Originally Posted by sata3000' timestamp='1333707952' post='21581812
So how much is a blown motor worth?
Sent from my SPH-D710 using Tapatalk
Still what I'm trying to figure out.
You're going to have to crack it open and assess the damage to get a reasonable answer on this. Anyone buying it is going to want to know what's wrong with it. " I dunno" is not very reassuring from a buyer's perspective and you can count on a LOT less money that way.
A properly functioning, low mileage motor can be had for about $3000. A motor with block only damage, maybe $1500. A motor with block and head damage, less.
weekendwarrior44
01-19-2017 02:20 AM
drhess06259
06-09-2010 05:36 PM
nutar
08-12-2006 03:10 AM
Billman250
10-27-2005 01:50 PM
sorenj
08-03-2003 01:41 PM
Quick Reply: Blown Motor....What's it worth?
