Bleed brake fluid with every brake pad change?
I just did a brake bleeding probably about 15-20k miles ago. Im about to do my front pads this weekend and wondering if I need to rebleed after every change?
thanks
thanks
Originally Posted by Saki GT,Apr 13 2009, 06:04 PM
No. Be careful about spillage from the reservoir though if you did your fluid when the pads were worn.
If you don't know what Saki is talking about... be careful if you've topped off your brake fluid. When you push back the pistons you'll push the fluid back into the reservoir.
Not a bad idea to bleed out enough to fit your new pads (if you topped off your fluid in between pad changes).
I love my speed bleeders.
Luc
09-10-2003 09:44 PM
