Big Brake Kit on stock wheels..
Was wondering if anyone has upgraded there brakes with any big brake kit, and is still using there stock wheels. This question I guess goes to the 04 owners because i'm pretty sure it they wont fit the pre04 rims. The Brembo requires 17in or + for it to fit, but I have not yet seen someone with this set up on stock wheels. Just curious.
Wilwood's 6-pot w/ 12" discs may fit in the 17" '04 rims...
They'll fit in '00-'03 16" rims w/ a 3mm spacer.
Wilwood's 4-pot BBK w/ 12" discs will fit in pre '04 16" rims.
im running stoptechs on my 04 but i have aftermarket rims. you will need to run a pretty agressive spacer with stoptechs with stock wheels. im running a 7" wide wheel upfront with a 42 offset and a 6mm spacer, putting it down to a 36 which is really low, but surprisingly doesnt stick out, although it does rub the inner fender a bit.
