Auto down window?
Old 10-03-2007 | 09:20 AM
theSILVERone's Avatar
Default Auto down window?
Wasn't sure what section to post in. But anyway, I just bought my 01' S2k. The auto down window switch for the drivers window does not work. The window does roll down but not by itself. i tried programming it by holding it down for 15 sec and pulling it up for 15 sec. It will work after that but after I turn the car off and start it back up it won't work again. Also, when I drop the top ther drivers window only drops a little bit not all the way like the passenger window. I am not sure if it is the the module for the window is bad or what? Any ideas??
Old 10-03-2007 | 09:24 AM
rocrfella's Avatar
LOL, my driver's window rolls down really fast, by the time auto kicks in, it's already down like 1/3 of the way. This feature works better with bigger windows.
Old 10-03-2007 | 09:34 AM
Sabre's Avatar
I think that the window control unit is known to fail on older models sometimes.
I cant remember exactly but you might try searching through the TSBs.
Old 10-03-2007 | 09:38 AM
Triple-H's Avatar
You need a new window relay, this is a common problem on the earlier models
Old 10-03-2007 | 12:14 PM
Sabre's Avatar
^^ Yeah..what he said
Old 10-03-2007 | 09:24 PM
wanabe's Avatar
i never bothered fixing mine... cause the reports were that the fix would also break.
is there a relay that fixes this for good now??
Old 10-03-2007 | 09:48 PM
Cool! Good to know that is an easy fix!! thanks
Old 10-03-2007 | 09:49 PM
Dan H's Avatar
Does passenger side have auto-down controlled through driver side switch? Or is it just driver side only?
Old 10-03-2007 | 10:09 PM
Driver side only... Oh and its the window regulator that goes bad....Just looked up the TSB...
Old 10-03-2007 | 10:11 PM
DSKC's Avatar
is there a way to do this for the passenger side window as well?
s2k harry
13
08-27-2009 08:18 AM
crav3s2k
01-27-2008 12:37 AM
CrazyIvan
08-23-2007 11:02 AM
Prolene
09-18-2002 07:56 PM
