AUT Cooling Plate install?
I am finally getting around to installing my AUT cooling plate and its thread in the group buy section that contained the link on how to install it is gone. I tried using the search function but it didn't turn up anything useful. If anyone has the link for the installation guide it would be greatly appreciated. I'm sure I could just wing it but I would feel more comfortable seeing what others have done.
Pretty easy.!
Remove the OEM air deflector,above the rad.( The slanted piece of plastic,in front the top of the rad.)
Unscrew the hood rubber seal,(5 or 6 screws)put the seal on the plate,screw it back.!!!
Here you go man. I have this plate also and it rocks!
https://www.s2ki.com/forums/index.ph...&f=22&t=308430
Hope this is what you want.
I was wondering the same thing. I was subscribed to that thread and it just disappeared.
sabruns02, your link is certainly helpful, but the thread that I'm looking for (and maybe the OP, as well) had pics and discussion about additional cheap/free mods for the cooling plate like lining your airbox, fitting some sort of "air director" into the cooling plate to get ram air, fitting tubing to the airbox to get secondary cold air from the wheel well, etc.
Anyone know what happened to this info?
I found this link... I know there is another pic of someone insulating the inside of their stock airbox somewhere but I can't find it now.
You can search "heat bog" in S2000 talk or under the hood and probably find more info.
https://www.s2ki.com/forums/index.php?showt...at%20bog&st=125
Originally Posted by Emil St-Hilaire,Nov 28 2005, 06:59 AM
P.M."Dolebludger".!!!
Anyway, I'm in the process of trying to reconstruct dolebludger's info and pics from the AUT group buy thread. Stay tuned.
