Armrest Pad Coming Off
Old 07-22-2004 | 07:21 AM
mattowens1023's Avatar
Default Armrest Pad Coming Off
I have a 2002 S2K and the black perforated armrest pad is coming off and looks disgusting. I talked to the dealer and they want $250 to fix it (I think they have to order the whole center console). Anyone have any suggestions on what to do to fix the problem? Are there any aftermarket parts that replace just the armrest pad? Thanks in advance.
Matt
Old 07-22-2004 | 07:29 AM
turbo_pwr's Avatar
are you talking about the vinyl cover in the center console? If so, I think a new one from http://www.ricks2k.com in leather is cheaper then that. It comes with instructions as well.
Old 07-22-2004 | 07:39 AM
Hockey's Avatar
No, I think he means the "perforated armrest", attached as part of the center console.
Rick's sells the console cover that goes beneath it, which I have. You can order it in solid or perforated, but that isn't the issue.
The center console is sold as an all-in-one unit, unfortunately. Depending on the age of your car, check with HardTopGuy (a sponsor AND Honda dealership we love) and ask what he can do for you. Joe and Jeff are fantastic, and will at the very least get you a good price on a new center console.
Good Luck,
Hockey
Gloffer's Avatar
Tell the dealer to do his job and perform TSB 03-012.
https://www.s2ki.com/home/index.php?option=...id=22&Itemid=41
Old 07-22-2004 | 07:42 AM
Hockey's Avatar
Too bad TSB are not recalls, or there would be a line at Honduh for all the TSBs out there.
Should be a warranty item if it is an '02, though.
Old 07-22-2004 | 07:54 AM
Elistan's Avatar
If the car is still under warranty, it should be fixed as such.
Old 07-22-2004 | 08:02 AM
Jason B's Avatar
https://www.s2ki.com/home/uploadfiles/a03-012.pdf
I can't load it.
Old 07-22-2004 | 08:23 AM
bobbyb's Avatar
I did a switch from a 03 consol to a 04 and sold the 03 .Yet from doing that install
it should be easy to fix .Do a search for 04 center consol mod there are complete instructions on removal also on ricks site there are some as well .it should be a easy fix .
Old 07-22-2004 | 08:38 AM
The car is no longer under warranty because it has 45k miles on it. And the rear of the pad is not lifting up like the service bulletin. The leather/vinyl is peeling off in the front. I think this is due to it getting wet (oops, forgot to put the top up) and then shrinking. I can't believe that you can't get this part individually. I wonder if I could get it at a junk yard. Or maybe I will send an email to Hardtopguy. Thanks for the help guys.
Matt
Old 07-22-2004 | 09:51 AM
steven975's Avatar
center consoles appear for sale frequently. there's one on ebay now. you're talking <$100.
you can get one NEW for about $135 from www.hondaautomotiveparts.com. go to the "center console) section.
Quick Reply: Armrest Pad Coming Off
