Ap2 cluster into a 01 s2000
Hi i have a 05 complete dash cluster harness and i was wondering if everthing will work if i put the ap2 cluster into the ap1, i see that the ap1 has 4 plugs and the ap2 has only too if i cut the wires and join them will everthing work and is everthing the same color.
the clock is built into the cluster. the tempature readout works off a sensor mounted in front of the radiator i believe. you might need to figure out how to wire that in
Originally Posted by djpepsi,Feb 18 2009, 05:04 AM
i wanna have the temperature and clock
BRRRRR - cold
PHEW - hot
Clock - lift up left wrist
Originally Posted by subsoniic,Feb 17 2009, 08:46 PM
ap2 cluster is dreadfully ugly.. why would u do such a thing
Thing is, if it's not plug and play, I don't see why you'd do it either. Quite a project all for wanting a clock and temperature. Good luck!!
AP1 cluster >> AP2 cluster
My '01 AP1 has a clock (in the radio). Your '03 doesn't?
Temperature? Can't you just let the window down a bit and feel what the temperature is?
